  2. Dear Toni, don't hesitate to email us your project at support@pvsyst.com so that we can replicate the issue and try to help you.
  3. No currently only a partial selection of variables can be added as monthly tables. However EUseful is actually a composite variable, it is equal to other variables depending on the case. For example, here it should be equal to "Energy from the sun".
  4. Today
  5. Since PVsyst 8.0.17, you have the possibility to use the "power shifting" strategy in Grid storage. If you do so and select "Fixed charging power before exporting" you can set it to charge as much as possible between 8 and 10. If the charging power is higher than the PV production, nothing will be injected to the grid. The main limitation for the moment is that any value you set will be applied every day for the whole year. Time series import should be available starting from PVsyst 8.1.0
  6. Could you please send us your project along with the 3D file at support@pvsyst.com Regards,
  7. Hi, I have the problem that when I select the "Automatic altitude" and set a distance to ground of 0,8m, PVsyst does not apply it. The panels are still going underneath the topology. Does anymone have a solution or advice ? Kind regards, Toni
  8. Yesterday
  9. Last week
  10. thanks for the reply, I tried it but it didn't solve the issue
  11. Hello, I would like to include the variable "EUseful - Useful energy output from the system" in the report but I can’t find it among the available options to select Is there any way to add it? I want this variable because it represents the AC energy delivered to the costumer
  12. Hi is it possible to set or simulate that during 8-10AM the plant will priotize to charge the battery and not inject to grid?
  13. Unfortunately, it’s not possible to import a PVsyst project created in version 8.0.4 into version 7.4.8. PVsyst files are only compatible from lower to higher versions, not the other way around. To open the project, you would need to use PVsyst version 8
  14. Sounds good, I look forward to the results. I would assume that the DIRINT or DIRINDEX model is the best bet, unless you would like to delve into Engerer...
  15. Still present in 8.0.16, don't see mention of correction in 8.0.17 or 8.0.18 release notes.
  16. Hello, In the current version, PVsyst simulation is hourly based. Thus any sub-hourly phenomenon has to be averaged. Sub-hourly simulation should be available in PVsyst 8.1, but the release date is not yet defined (Normally in the beginning of 2026). Nonetheless, we included a sub-hourly clipping correction in PVsyst 8.0, allowing the simulation to consider sub-hourly irradiance fluctuation for clipping. You can refer to the dedicated section in our help page for more information. The last option is to use the so-called pseudo-subhourly simulation. The idea is to run n hourly simulations (in your case n = 60min/30min -> 2 ) then recombine the results. You can find a PDF tutorial about the whole process in our website: Pseudo sub-hourly Simulation Kind regards
  17. Dear Bommu, When you open PVsyst, you can see an information box at the bottom of the main window that indicates the remaining validity period of your license. Additionally, you can configure your email subscriptions in your Web Account at https://www.pvsyst.com/shop/ to receive notifications when your license is about to expire. Best regards,
  18. I am trying to import a project file from 8.0.4 into PVsyst but I have version 7.4.8, is there a way this can be done? I keep getting error messages that say there are conversion errors and unrecognized enum values. Any help would be greatly appreciated, thanks!
  19. We update the database using the requests of the manufacturers, and publish it with each new release of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos.
  20. Dear Ziad, Can you also try this feature: Tools → Automatic altitude (see below)? Select your entire table first, then enable this feature. On the right, try setting 1 meter or more, choose Lowest point, and click Set automatic altitude. Let me know if this solves your issue. Regards,
  21. Hi, I would like to check if there is any existing feature in the software that provides a reminder or pop-up notification during login when the license is nearing expiry (e.g., 10 days or 1 day before). Currently, I do not see any such notification, which could lead to missed renewals and potential service disruption. Could you please confirm if this functionality is available or guide me on how to enable it? Thank you
  22. Hello everyone, I’m looking for PVsyst data files (.PAN) for different PV panel models from various manufacturers. If anyone can share these files or provide a reliable download source, I would really appreciate it. Thanks in advance
  23. Hello , I have a cad file containing contour lines and points of a site, I extracted the data from the cad file into a csv file containing X,Y,Z coordinates of all the points in it and imported it into PVsyst scene as a ground object , but the problem is that when I place the PV tables over it ,some of them are not placed properly
  24. Again, if you change any figure for the battery, it WILL impact your simulation. If you change the number of cells or the number of blocks or the number of racks, the battery characteristics will be impacted (voltage for the components in series, capacity for the components in parallel). The only issue I can see is the display of the number of UNITS in the grid storage window, which is not changed as it should when you change the number of blocks in the battery component. Now, if you have this values in your report (10*2 Units) but did not set 10 racks in series and 2 racks in parallel, please contact us at support@pvsyst.com with your project so we can have a better look at what's happening.
  25. In the DC circuit (array of strings), the total wire length is indeed the lenght of the whole loop (this si mentioned just below "Please specify the total wire length for each circuit. " For the AC circuit, this is the line length (distance between devices).
  26. Earlier
  27. Actually it counts in simulation. 20 batteries.
  28. I think you misunderstood what I meant. You can any number of cells, modules and racks and it will be taken into account during the simulation. Only this specific figure displayed here is false. But that's only for display, so it won't impact your simulation.
  29. Dear PVsyst Team, I would like to clarify the wire length definition used in PVsyst. Could you please confirm whether the following wire length inputs should be entered as **one-way length** or **two-way length**? 1. DC Circuit: String module connections / Main box to inverter 2. AC Circuit: Length Inverter to injection Thank you very much for your support. Best Regards, NaK
