  2. What dou you mean by "Types of cables" ? The different types of cable (of a same metal) have in principle the same resistivity, and this is the parameter which determines the power loss. If you are talking about the installation mode: - The resistivity may indeed depend on the cable temperature, and therefore on the installation mode. - The main thing to be considered will be the current limit for a given cross section, which is specified in norms.
  3. Unfortunately, it is not possible to put two different types of string on the same MPPT in PVsyst. You must either approximate the module rated power so that the MPPT are homogeneous, or you should redefine the inverter as having 6 MPPT, although this could somewhat affect the inverter losses.
  4. Yesterday
  5. Hi everyone. I want to ask if it is possible to import GPI data obtained from a PV plant with trackers into PVSYST in order to obtain an aproximation of the energy exported from the plant and compare with the real measured energy of the plant. I tried to import using the PVSYST standard format but it only allows one specific tilt angle for the GPI. Is it possible to import the GPI data obtained from a piranometer installed in the trackers to PVSYST and simulate with this GPI data? Thank you very much.
  6. Thanks for the detailed explanation about AC losses and reference power selection—it was very helpful. Could you also explain how using different types of cables might influence the system's overall resistance and consequently affect the ohmic losses?" If you want, I can create 3 more alternative versions of this question that are concise and professional. Do you want me to do that?
  7. Hi PVSyst Community, Is there a turnaround so I can define this config in the powersharing option in PVSyst? For context, 1A.PCS.7 uses SG4400 as inverter and at 27m/s. It exceeds the 4MPPT capacity of the inverter and the PVSyst reads this configuration as 2 INV instead of 1. MPPT1 - 585W - 81str MPPT2 - 585W - 82str MPPT3 - 585W - 47str 590W - 36 str MPPT4 - 590W - 20 str 595W - 60 str Thanks for the help!
  8. Last week
  9. Dear Nikoloz, Here are two videos for the standalone project: Regards,
  10. Dear Toni, don't hesitate to email us your project at support@pvsyst.com so that we can replicate the issue and try to help you.
  11. No currently only a partial selection of variables can be added as monthly tables. However EUseful is actually a composite variable, it is equal to other variables depending on the case. For example, here it should be equal to "Energy from the sun".
  12. Since PVsyst 8.0.17, you have the possibility to use the "power shifting" strategy in Grid storage. If you do so and select "Fixed charging power before exporting" you can set it to charge as much as possible between 8 and 10. If the charging power is higher than the PV production, nothing will be injected to the grid. The main limitation for the moment is that any value you set will be applied every day for the whole year. Time series import should be available starting from PVsyst 8.1.0
  13. Could you please send us your project along with the 3D file at support@pvsyst.com Regards,
  14. Hello is there any video tutorials for standalone systems ? what I could find is only ongrid systems. and also offgrid videos but on "hindi english" which I dont understand
  15. Hi, I have the problem that when I select the "Automatic altitude" and set a distance to ground of 0,8m, PVsyst does not apply it. The panels are still going underneath the topology. Does anymone have a solution or advice ? Kind regards, Toni
  16. thanks for the reply, I tried it but it didn't solve the issue
  17. Hello, I would like to include the variable "EUseful - Useful energy output from the system" in the report but I can’t find it among the available options to select Is there any way to add it? I want this variable because it represents the AC energy delivered to the costumer
  18. Hi is it possible to set or simulate that during 8-10AM the plant will priotize to charge the battery and not inject to grid?
  19. Earlier
  20. Unfortunately, it’s not possible to import a PVsyst project created in version 8.0.4 into version 7.4.8. PVsyst files are only compatible from lower to higher versions, not the other way around. To open the project, you would need to use PVsyst version 8
  21. Sounds good, I look forward to the results. I would assume that the DIRINT or DIRINDEX model is the best bet, unless you would like to delve into Engerer...
  22. Still present in 8.0.16, don't see mention of correction in 8.0.17 or 8.0.18 release notes.
  23. Hello, In the current version, PVsyst simulation is hourly based. Thus any sub-hourly phenomenon has to be averaged. Sub-hourly simulation should be available in PVsyst 8.1, but the release date is not yet defined (Normally in the beginning of 2026). Nonetheless, we included a sub-hourly clipping correction in PVsyst 8.0, allowing the simulation to consider sub-hourly irradiance fluctuation for clipping. You can refer to the dedicated section in our help page for more information. The last option is to use the so-called pseudo-subhourly simulation. The idea is to run n hourly simulations (in your case n = 60min/30min -> 2 ) then recombine the results. You can find a PDF tutorial about the whole process in our website: Pseudo sub-hourly Simulation Kind regards
  24. Dear Bommu, When you open PVsyst, you can see an information box at the bottom of the main window that indicates the remaining validity period of your license. Additionally, you can configure your email subscriptions in your Web Account at https://www.pvsyst.com/shop/ to receive notifications when your license is about to expire. Best regards,
  25. I am trying to import a project file from 8.0.4 into PVsyst but I have version 7.4.8, is there a way this can be done? I keep getting error messages that say there are conversion errors and unrecognized enum values. Any help would be greatly appreciated, thanks!
  26. We update the database using the requests of the manufacturers, and publish it with each new release of PVsyst. We can't of course follow all the new products of all manufacturers in the world. We don't want to include data without the acknowledgement of the manufacturer. Nevertheless you can easily create your own components by yourself. The easiest way is to choose a similar existing device in the database, modify its parameters according to the manufacturer's datasheets, and save it under a new name, therefore creating a new file in your database. You have a tutorial for that on youtube: https://www.youtube.com/c/PVsystTutos.
  27. Dear Ziad, Can you also try this feature: Tools → Automatic altitude (see below)? Select your entire table first, then enable this feature. On the right, try setting 1 meter or more, choose Lowest point, and click Set automatic altitude. Let me know if this solves your issue. Regards,
  28. Hi, I would like to check if there is any existing feature in the software that provides a reminder or pop-up notification during login when the license is nearing expiry (e.g., 10 days or 1 day before). Currently, I do not see any such notification, which could lead to missed renewals and potential service disruption. Could you please confirm if this functionality is available or guide me on how to enable it? Thank you
  29. Hello everyone, I’m looking for PVsyst data files (.PAN) for different PV panel models from various manufacturers. If anyone can share these files or provide a reliable download source, I would really appreciate it. Thanks in advance
