Brooke Sargent joined the community
Aubrey Stafford joined the community
Addren joined the community
- 3d shadings
- near shading 3d scene
- 3d shadings
Luna joined the community
Atiika joined the community
Sounds good, I look forward to the results. I would assume that the DIRINT or DIRINDEX model is the best bet, unless you would like to delve into Engerer... - Earlier
