Sanda Vulindlu joined the community
Hello, If all the strings have the same length you can indeed use the Power sharing within the inverter. The two options should give the same result. - Last week
Hanaa joined the community
Tina Dornbusch joined the community
m.hajda joined the community
Alex.l joined the community
Reycuba joined the community
mcolonel joined the community
