HOSSOU joined the community
To compare with baseline pvlib, I would rather remove 2 cm to the "Sensitive width". Might be 1 cm, I am not 100% sure if 2 is double counting. - Today
Hector Hernandez joined the community
Michele Oliosi started following PVSyst vs pvlib tracking angle comparison
kapetav joined the community
Salih joined the community
Jun Lei joined the community
Arisa joined the community
- 8 replies
- irradiance
- rpoa
(and 5 more)
Botros joined the community
thanks!
