  2. Dear Carlos, We don't have any specific procedures or instructions regarding existing plants. If PVC format is not available, DAE or 3DS can be used. Then on the import screen you can select the "material" that is used for your trackers and you can define the tracking parameters there. Also for the terrain, you can select its material and PVsyst will import it as a ground object. Here is the link of our help page for importing 3D file, where you will find more details: https://www.pvsyst.com/help/project-design/shadings/near-shadings-import/sketchup-and-other-cad-software.html#scene-details
  3. Dear Pattarporn, don't hesitate to email us your project at support@pvsyst.com so that we can replicate the issues and try to help you.
  4. Today
  5. Yesterday
  6. This looks like an AI bot or something...
  7. Hi, I usually build the 3D scene for new ground mounted projects using a commercially available tool that exports the layout as PVC file and direct imports into PVsyst 3Dscene. this is very fast and useful for trackers. but now I want to evaluate the near shadings of an existing plant (with trackers) with the drone scan and Metashape postprocessing. How do I "assign" the tracker characteristic's to the imported object? is there a preferred file format for pv objects, shading objects and terrain? is there a recommended procedure for this real 3d Scene mounting on PVsyst? is there a recommended software or tool?
  8. Hello, I have run PVsyst 8.0.15 for one project, a Solar Rooftop, and encountered the following issues: Running PVsyst with 3D or Near Shading enabled takes approximately 1 hour and 30 minutes, even though the 3D model does not contain any complex structures. I have therefore set it to run in Fast mode. How can this issue be resolved? In the Detail Loss section, I set the Soiling Loss to 3.5%, and the report correctly shows 3.5%. However, in the Loss Diagram, it displays as 3.25%. How can this discrepancy be corrected? Since I ran the 3D simulation, and the site is expected to have significant shading based on the site survey, I was surprised to find that the Near Shading loss is displayed as a positive value in PVsyst. How can this occur, and is there a way to adjust the settings so that the value appears as negative?
  9. @sauld no you are right, there could be some losses that would be missed by this approximation. Unfortunately this is a compromise, because currently MPPTs can only receive identical strings in the System definition in PVsyst. However for most cases these losses are rather small. The most important is the string to string mismatch (usually shading effects are even smaller because you need a very specific shading pattern for the multi-MPPT to help). You could add an estimate of these losses to the mismatch losses manually. You can estimate them using a tool found from Home window > Tools. There is a similar discussion here (see the last answer by my colleague Luca):
  10. Last week
  11. Thank you Jérémie for your promot reply...
  12. Hi! Yes E_Grid is an "active" energy/power. You can find explanation about active, reactive and apparent energy on the page: https://www.pvsyst.com/help/project-design/grid-connected-system-definition/power-factor/index.html?h=power+facto#apparent-reactive-and-active-power-definition The table at the end of the page give you the different definitions: Upon defining a power factor through the menu "Energy Management / Power Factor", the two additional variables EReGrid and EApGrid become available in the detailed results and also appear in the loss diagram.
  13. Hello Toni, The zone editing tool only supports fixed tables and trackers. If you need trackers, please tick the “Create tracking fields” option. For dome structures, there is no direct way to use the Fill Zone tool. However, you can refer to the following forum post, which suggests a possible workaround
  14. This is a known, but benign, issue where the total AC power is not always well recomputed when you have inverters with MPPTs connected to varying DC power. This is due to the total AC power being the sum of each MPPT equivalent AC power, itself based on the power sharing options. This approach is necessary to be able to deal with fraction of inverters, but may lead to small discrepancies in total. We will solve that in a future PVsyst version.
  15. I think this is a very valid concern — getting –5.8% “unused energy” in your simulation seems unusually high, especially since it drops to –0.1% when you remove ohmic losses. It might be worth sharing your full project file with PVsyst support so they can help you diagnose whether the grid limitation is being modeled correctly.
  16. Hi, I am trying to run a stand alone project, but when I choose a bifacial module, the bifacial feature does not seem to show... Isn't it possible to simulate bifacial modules in stand alone projects? If it is not possible, is there a workaround to this? Beste regards, Rafael
  17. Reviving old thread, but I don't think this would be a very accurate way of modeling this issue. As I'm getting higher production total with less total DC nameplate(assuming due to the virtue of multi mppts helping with mismatch between shaded/unshaded sections) In reality the string/s of different wattage module would negatively impact a combiner due to the mismatch of overall Vmp. Unless there is something I'm not thinking about.
  18. Hallo, can you give more explaination about handrail tilt. I cant get it
  19. The units suggest that this is active power, but please can someone confirm whether this is the case?
  20. Hi, I am struggling with a rather simple problem but is it possible to convert a field with fixed tilt tables directly into domes or tracker ? When I change from fixed tilt to domes in the orientation menu and afterwards try to fill out the zone in the 3D scene, the zone is again filled with fixed tilt tables, even if I change the orientation in the 3D workspace.... Is there another approach how to? When I do the changes in the 3D scende first, I get the error that there's no field Any helping advice would be welcome Kind regards, Toni P.S.: I am using PVsyst vers. 8.0.13
  21. Great question — 15-minute simulation support would be very useful. Hope the team can share if this feature is planned and when we might expect it!
  22. Hi, I am modeling a complex project using various different string lengths and solar optimizers. There are 48 inverter units (these are SolarEdge SE120s, so I am actually modeling 16 inverters with 3x 40kW units in each), and in the global system summary it accurately calculates 1920 kWac. However, in the report, the total power is noted as 1918 kWac. What is causing this discrepancy? Thank you!
  23. Hello, You can import Measured global on plane (GlPMeas) via the "custom file" tool. You then need to define the Orientation definition and here you can define a tracker. PVsyst will reverse engineer (we use the term reverse-transpose) the GHI and DHI. In the end the discrepancy between the original value and the one in the simulation will differ for a given hour of less than a percent. Over the year the difference should be negligible. You should use the Hay transposition for more robust results with the retro-transposition. This is further explained in the following PVsyst help: https://www.pvsyst.com/help/glossary/solar-geometry/plane-orientation.html
  24. What dou you mean by "Types of cables" ? The different types of cable (of a same metal) have in principle the same resistivity, and this is the parameter which determines the power loss. If you are talking about the installation mode: - The resistivity may indeed depend on the cable temperature, and therefore on the installation mode. - The main thing to be considered will be the current limit for a given cross section, which is specified in norms.
  25. Unfortunately, it is not possible to put two different types of string on the same MPPT in PVsyst. You must either approximate the module rated power so that the MPPT are homogeneous, or you should redefine the inverter as having 6 MPPT, although this could somewhat affect the inverter losses.
  26. Hi everyone. I want to ask if it is possible to import GPI data obtained from a PV plant with trackers into PVSYST in order to obtain an aproximation of the energy exported from the plant and compare with the real measured energy of the plant. I tried to import using the PVSYST standard format but it only allows one specific tilt angle for the GPI. Is it possible to import the GPI data obtained from a piranometer installed in the trackers to PVSYST and simulate with this GPI data? Thank you very much.
  27. Earlier
  28. Thanks for the detailed explanation about AC losses and reference power selection—it was very helpful. Could you also explain how using different types of cables might influence the system's overall resistance and consequently affect the ohmic losses?" If you want, I can create 3 more alternative versions of this question that are concise and professional. Do you want me to do that?
  29. Hi PVSyst Community, Is there a turnaround so I can define this config in the powersharing option in PVSyst? For context, 1A.PCS.7 uses SG4400 as inverter and at 27m/s. It exceeds the 4MPPT capacity of the inverter and the PVSyst reads this configuration as 2 INV instead of 1. MPPT1 - 585W - 81str MPPT2 - 585W - 82str MPPT3 - 585W - 47str 590W - 36 str MPPT4 - 590W - 20 str 595W - 60 str Thanks for the help!
  30. Dear Nikoloz, Here are two videos for the standalone project: Regards,
