Bhumika joined the community
Mangesh Punekar joined the community
Andi joined the community
AMUDHA joined the community
Zelon8 joined the community
SM24 joined the community
JRMiguel joined the community
Luzed6 joined the community
Miguel G joined the community
Edson08 joined the community
With the option "Load values from a CSV hourly file" you have full liberty to define the load profile exactly how you wish.
