Gustavo Pianovski started following the problem of discontinuity in simulation
Kelsey Lou joined the community
Bhumika joined the community
Mangesh Punekar joined the community
Andi joined the community
AMUDHA joined the community
Zelon8 joined the community
SM24 joined the community
JRMiguel joined the community
