Hello, If all the strings have the same length you can indeed use the Power sharing within the inverter. The two options should give the same result. - Yesterday
Hanaa joined the community
Tina Dornbusch joined the community
m.hajda joined the community
Alex.l joined the community
Reycuba joined the community
mcolonel joined the community
maxwell joined the community
