Bhumika joined the community
Mangesh Punekar joined the community
Andi joined the community
AMUDHA joined the community
Zelon8 joined the community
SM24 joined the community
JRMiguel joined the community
Luzed6 joined the community
Miguel G joined the community
Edson08 joined the community
So I have to work the profile as .CSV File If I want to seperate the profile for all month right? That's fine then, Thank you very much!
