  2. Hi PVSyst team, Happy Thanks giving from Korea. Moving on the main point, There`re some situation typing in a box manually with different datas such as ground albedo, soiling losses. For a case above, When I type data monthly basis i use "tab" button but somehow it move to another box without my intention. For example, It moves to Sep to Apr , or Nove to July. I believe this can be solved easily and will give good user-friendly satisfaction to customers for program UI respect.
  3. Dear PVsyst team, We often run large and complex simulations in which the shading computation (even using fast table method) takes up to several hours. Often we leave the machine working at night and get the results in the morning but we have no way to know when the computation actually ended. This info would be helpful for the future, so we can know in about how long we could run a new variant with similar shadings. While the computation is running, we can see how long it took so far so, when finishing, it would be enough to keep the last value of elapsed time on screen somewhere. Now it closes with the progress bar and there is no way to retrieve it (correct me if wrong). Would it be possible to add this functionality in a future patch? Best regards
  4. Yesterday
  5. Hello, We updated our website and the new URL is : https://www.pvsyst.com/en/products/old-versions/
  6. Hello, We updated our website and the new URL is : https://www.pvsyst.com/en/products/old-versions/
  7. Hello I used 3d auto batch zone feature and have been wondering why there are some module transprency existed in the edge of array. Can you explain what does it mean ? and what it can affect to simulation? Thank you.
  8. Last week
  9. I'm getting a 404 Error for URL: <https://www.pvsyst.com/old-versions/> (i.e., the link for downloading past versions of PVsyst) Thanks.
  10. How to install previous version of PVsyst? The link is not working: https://www.pvsyst.com/download-pvsyst/
  11. Dear ShivamPandey, Please email us your PVsyst LOG files (using menu <File> <Export logs>) at: support@pvsyst.com so we can analyze what happened and try to reproduce the issue you reported. Best regards.
  12. Dear ShivamPandey, Please email us your PVsyst LOG files (using menu <File> <Export logs>) at: support@pvsyst.com so we can analyze what happened and try to reproduce the issue you reported. Best regards.
  13. Hi I have an older Pvsyst project export zip file, but when importing it into PVsyst, it is showing the following errors. Older project is created witjh PVsyst 8.0.5 Zip Folder contains all the files exported. Same is the issues with the background image imported from map service within the near shading. Map is not showing up when imported into a different machine or PVsyst
  14. PVsyst Having the same issues, any solution for this
  15. All the most important losses are illustrated in the loss diagram that is generated after running the simulation. Here you can clearly see what kind of losses your project suffer from. The P90 will depend on the variability and uncertainties you define in the Energy management window.
  16. Dear Andres, Unfortunately, this is a bug with PVsyst version 8.0.16 and we will fix it in future releases. The bug also affects importing "meteonorm software (*.hor)" data. In the meantime, several workarounds are possible: Import horizon data from meteonorm API ("horizon from web sources") Copying your .hor file in the PVsyst8.0_Data/Shadings folder and importing it with the "PVsyst internal file" option If neither options above work for your situation, reverting back to PVsyst 8.0.15 https://www.pvsyst.com/old-versions/ I hope this solves your issue
  17. Earlier
  18. What are the factors that affect a high specific production and P90 value? I am working on multiple simulations and there is one simulation that always has a high yield (kWh/kWp/day) and I can't figure out why.
  19. PVGIS horizon imports are currently not working properly as they are only importing 180deg of the horizon from 0deg to 180deg and not including -180deg to 0deg. This is a problem with both 5.2 and 5.3 currently.
  20. Greetings all. The recently released version 8.0.16 introduced the feature of including object shading in the calculation of diffuse shading in 3D model. However, I noticed that when using this feature, the values for near shading losses do not match the values when using the ‘all trackers’ feature. All trackers: Custom tracker with object shading included: In addition, using the “object shading” feature causes the software to crash.
  21. Dear Ziad, Without the project, I can’t know what the issue is. Could you please send us your project at support@pvsyst.com and explain what the issue is? Regards, Muhammed Sarikaya
  22. Hello, There is something I can't fully understand , Shouldn't there be a limit for energy generation (Euseful) as Pnom ratio (DC/AC) is increased then Euseful should decrease again because of the overload losses? because I noticed that generation keeps increasing as i continue to add more strings for the same inverter till reached the max number of strings allowed. Thanks.
  23. Hello, there is no dedicated building element for such a parapet. However you can use elementary shading object like parallelepiped all around the roof edge.
  24. Hi Hizir, Thank you for your reply. I see the Regular and Bold for Airal Unicode MS fonts in the C:Windows>Fonts folder. Fortunately, my company installed an update for PVsyst this morning and now I can view and print reports again. Hopefully it will stay this way! Thanks again, Ben
  25. Hi there, I’m struggling to model a parapet around my Near Shadings building in PVsyst. The parapet is 0.3 m wide and runs along the roof edges. Is there a recommended way to create this? I tried adding a 0.3 m-high wall around the building edges, but that feels a bit rudimentary. Is there a more efficient tool or feature for this? Thanks in advance!
  26. The structure shading factor is design to reflect the area covered by the structures. The electrical effect of this shading should be reflected in the mismatch loss factor. Thus if I understand your example correctly, the mismatch loss factor should be set to 40% if 40% of a cell in the concerned sting is shaded. For the structure shading factor, define only the ratio of the area covered by structures to the photovoltaic area.
  27. This is quite normal as you have defined a grid limitation of 1 kW (for a system of 200 kWp, 180 kWac). You can notice that the apparent value is 79 kVah, to be compared to a global delivery to the user of 224 MWh, i.e. 0.04%. Please note that you have the opportunity of completely forbid the injection to the grid when you define the self-consumption:
  28. Understood - thanks for your response!
  29. Dear Ben Arial Unicode Bold and Arial Unicode Normal font seem to be missing from your computer. Could you please check that you have it installed in your C:Windows>Fonts folder (Normal and Bold should appear for Arial Unicode MS) : If not you can install it from here: https://freefontsdownload.net/free-arial-unicode-ms-font-36926.htm If the problem remains, please export and send your log files to support@pvsyst.com by using menu "File>Export logs" Kind regards,
