JacksonCarroll joined the community
jianke1985 joined the community
I see ! I just remembered that in this version (7.2) there is a bug for trackers. In the object management window, the number of partitions is not affected to the right variable. It is connected to the size of the partitions instead which in turn makes it not work. Please use option 3 or update the PVsyst version.
You are right, it was a typo, my version 7.2. Do you have any idea why my shading scene in method one does not show proper shading animation? I don't even see the dotted lines that show partitioning is done, but the shading factor table looks good for a backtracking which is 0 everywhere. I afraid that it produces zero because shading is not working at all and not because of correct partitioning.
Michele Oliosi started following Partitioning
Hi, There is no object management window in PVsyst 6, so I assume you are using a more recent version. Which version are you using ? I have tried to see if solution 1 had a bug in version 8.0.19, but everything works fine. You are probably correct that solution 2 may have an issue sometimes. The zone tool is rather old and sometimes misbehaves. Solutions 1 and 3 should be equivalent.
Dharani joined the community
Akmal joined the community
shola joined the community
Luca Antognini started following Arev factor of BC modules in string level simulation
Dear Jianguo Chen, Thank you for your feedback. I share your understanding : both dialogues, with those parameters, should lead to the same results. For me the correct plot is your top screenshot, from the menu "One shaded Module". I noted that this problem seems to happen only with "Twin-half-Cut" module: If I select a "In length" module, both dialoguess give me the same results I think therefore there is a problem with the calculation of the electrical layout in this specific dialog. I will create an issue to investigate it further and fix this problem in a future version. -
Andreacuellar26 joined the community
I have monthly weather data for TMY data (Meteonorm 7.3). Could you please advise how to input this data into PVsyst and how to display it in the simulation report? The available data includes monthly ambient temperature and global horizontal irradiation, as shown below: Month Ambient Temperature (°C) Global Horizontal Irradiation (kWh/m²) January 7.5 92 February 8.8 106.5 March 12.7 159.7 April 16.6 187.7 May 21.2 230 June 24.5 242 July 26.8 245.3 August 26.2 225.1 September 23.5 182.9 October 20.5 144.6 November 13.7 104.7 December 9.5 87.2 Year 17.6 2007.7
