PatrickDoyle joined the community
Katie joined the community
Sorry I don't really understand what you want to. The Ohmic losses can be defined in the Detailed losses window - Yesterday
Stephan Sartor joined the community
solsken energy llp joined the community
bab joined the community
Aya_SoranoAI joined the community
icicle joined the community
Bengar9 joined the community
