Why not adjust the bifacial albedo to 0.7?
Hi, thanks for your replay You mean BkVFLss * GCR = BkVFLss_refers_to_ground? I checked these variables relationship: GlobBak = ReflBck + DifSBak - BackShd (assume BeamBak = 0) But what is relationship among ReflBck, BkVFLss_refers_to_ground, ReflLss, GlobGnd? - Yesterday
sakib joined the community
Siping joined the community
Brigitte joined the community
Vatsaa joined the community
WillShif joined the community
