Myron joined the community
sofya joined the community
Irtubes joined the community
Hello @Robin Vincent, I had a quick question related to a similar scenario. The system I’m working on has a target AC capacity of 900 kW. In PVsyst, I’ve modeled this using 27 units of 33.3 kW (SE100KUS equivalent), which corresponds to 9 inverters. However, PVsyst reflects the total AC capacity as 899 kW (27 × 33.3 = 899.1 kW, rounded). I wanted to clarify the following: Does PVsyst internally use 899 kWAC or 900 kWAC for generation calculations in this case? What would be the best way to model the system so that the AC capacity reflects exactly 900 kWAC instead of 899 kWAC? Appreciate your guidance on this. Thanks!
