Wahid Hussain Shah joined the community
indonesiaescortspage joined the community
Oisin joined the community
sauld joined the community
phihash5 joined the community
mut joined the community
JohnC18 joined the community
huybaor joined the community
roni_hajianto joined the community
- 3d shadings
- near shading 3d scene
- 3d shadings
Sounds good, I look forward to the results. I would assume that the DIRINT or DIRINDEX model is the best bet, unless you would like to delve into Engerer...
