Gustavo Pianovski started following the problem of discontinuity in simulation
Kelsey Lou joined the community
Bhumika joined the community
Mangesh Punekar joined the community
Andi joined the community
AMUDHA joined the community
Zelon8 joined the community
SM24 joined the community
JRMiguel joined the community
Luzed6 joined the community
Miguel G joined the community
Hello, In general, far shading affects the entire PV field uniformly — at any given moment, the sun is or is not visible on the field. As a result, it can potentially reduce the impact of near shading, since far shading may occur during times when near shading would otherwise be present, typically when the sun is low on the horizon. - Earlier
