  2. This is not a precise science and can be site dependent. In order of magnitude, one could consider that a site within 10km distance can use the same .MET and .SIT without issues.
  3. If I were to do multiple simulations of different facilities, but they are in the same area, meaning they are on the same block, and I will import a weather data from meteonorm, can I just use the same .MET and .SIT file for all of them?
  4. Yesterday
  5. Yes, I used trackers, with backtracking (same as the actual system):
  6. Last week
  7. One of your answer above I read that, you say I will write no of sheds relate to no of rows mean if I install 4 panels in a row and have 4 rows then no of sheds will be 4, but one thing confusing that I'm installing a 10.32KW system for installation with 645W panel capacity, but there is no limitation of no of sheds mean when I increase no of sheds my end from 16 to 60 then also pvsyst simulate and give less production result.
  8. i don't understand the logic, one thing I'm understand is that I make a mind that 16 panels 16 rows that's why I use 16 no of sheds but at the end this thing confused me that why by increasing the no of sheds from 16 simulation run it should be stop by the software bcz in system design we only use 16 panels bcz it affects on production, plz understand me the logic of no of sheds plz
  9. In the detailed losses window, you can set 1% for the first year degradation as a LID loss in the "Module quality - LID - Mismatch" tab and 0.44% as an average degradation factor in the Ageing tab.
  10. How can I account for the degradation losses in PVsyst 7? What I want to input are the following: 1st year degradation: 1% Succeeding years' degradation: 0.44% loss per year
  11. Earlier
  12. Hello, For a current project we are exploring using the module temperature from the pvsyst for contractual purposes. I tested the advanced simulations with all of the module temperature related features turned on. the TExtON or average ambient temperature during running produces an answer of 0,0 every time meaning that the other temperature items that check the module temp compared to ambient temp also do not work. This is all seen in the latest version of pvsyst, with both linear and detailed electrical projects and when using multiple different sources for the TMY file.
  13. Hello Carlos, PVsyst simulations are limited to a maximum period of one year. Accordingly, the associated weather data file is also limited to one year, and any data beyond 365 days in a custom-imported file are ignored. If your dataset covers more than one year, you will need to run separate simulations, each using its own corresponding weather data file. Additionally, since your measurements contain missing data, I would recommend isolating the reliable and consistent measurement periods into separate files using a text editor. These cleaned files can then be reimported using the Import and Generate Custom File tool. Best regards, Eric
  14. Hello. To better assist you, please send your project to support@pvsyst.com (File / Export projects) and be specific about the name of the orientation with wrong values. Regards
  15. After the latest PVsyst update, I can no longer find the auto-detect orientations tool. When defining orientations from the selection, the software creates nominal values that differ from the average values of the selected objects, and these nominal values cannot be edited. I would like to understand: Why the nominal values differ from the average values of the objects, How to correct or align them, And how this difference affects the energy yield and overall model results. Any guidance would be appreciated.
  16. Hi, LID is a degradation pathway, which you can see as a definitive change in the module performance. It occurs in the first hours of exposure to sunlight, but then the effect remains. Degradation is modeled as a fixed ratio for the whole year, but in reality this loss should increase throughout the year. This is why we choose the mid-year mark as representative for the yearly degradation loss factor. Hence the 50% applied on the first year. Module array mismatch loss is different from degradation, you find its value in "Detailed losses > Module quality, LID, mismatch"
  17. What are the testing conditions for Arev? thanks!
  18. Hi all, I have a 10 min step time-series from 06/2022 to 10/2025. I also have a couple of missing months and values in between because they are real and filtered measurements. when I "import and generate weather data" from "custom file" I created the MEF that fits the format of my CSV meteo data file. When checking the data quality only one year appears and appears with the missing months from that year, even when for the following years I had enough data to cover the hole. I also have significant outliers in time shift. I know my data measurements are limited to be considered as representative, but why does the model discard the info after the first 365 days?
  19. Hello. Please send the export of your project to support@pvsyst.com so we can have a closer look at it (Project / Export the project)
  20. Dear Diana, You can generate graphs and plots through the detailed results window (pre defined graphs or hourly graphs for a large amount of simulation parameters). In the Advanced Simulation window, you have additional freedom to create custom plots that also can be included in the report. Another possibility is indeed to create an Output file with the relevant parameters and do the analysis in an external tool. Kind regards
  21. Dear PVsyst Team, I would like to know whether PVsyst can generate a graph of PV power output as a function of solar irradiance and ambient temperature. Is it possible to obtain this directly within PVsyst, or through exported simulation results that correlate PV power output with these two variables? Best regards,
  22. I ran a simulation with a 30-year projection and, when reviewing the loss diagram, I noticed that the LID degradation (1% in this case) applies not only in the first year, but throughout the 30 years. Is this correct, or am I misinterpreting the result? Highlighted in green. Furthermore, when reviewing the module degradation loss for year 1, in addition to the 1% LID, the model applies a degradation loss of 0.20%, which corresponds to 50% of the annual degradation rate of 0.40% from year 2 onwards. However, we also note that this same 0.20% appears in the module matrix mismatch loss. Wouldn't this mean that the loss is counted twice? Highlighted in blue. Could you clarify whether this interpretation is correct and why this is the case? Best regards,
  23. Hello, I ran a simulation with a 30‑year projection, and when reviewing the loss diagram, I noticed that the LID degradation (1% in this case) is being applied not only in the first year but throughout all 30 years. Is this correct, or am I misinterpreting the output? Higlighted in green Additionally, when reviewing the module degradation loss for Year 1, aside from the 1% LID, the model also applies a 0.20% degradation loss, which corresponds to the 50% of the annual 0.40% degradation rate starting from Year 2. However, we also see that this same 0.20% appears in the module array mismatch loss. Wouldn’t that mean the loss is being double-counted? Higlighted in blue Could you please clarify if this interpretation is correct and why it is the way it is. Grretings,
  24. The bifacial model presently available in PVsyst is based on a simplified 2-dimensional representation, with similar assumptions as the "unlimited sheds" or “unlimited Trackers” PVsyst simplified calculation. This approximate calculation may be extended to a 3D scene, provided that this 3D scene is sufficiently well represented by the "Unlimited sheds or trackers". You can read more about the bifacial model conditions in the following help page: https://www.pvsyst.com/help/project-design/bifacial-systems/2d-bifacial-model-conditions.html With multiple orientations and sub-systems with different table width, you can in version 8 create new "orientations" in the orientations window and group all the tables with similar characteristics in a sub-system/orientation, and apply the bifacial model to each sub-system in the system window
  25. As you can see in the frames above what you have highlighted ("Number of rectangle-strings"), on your table there is a non-integer number of partitions. This means that either your tables are not consistent with the string length (can be an integer multiple or a simple fraction), or the length 31.75 is not exactly correct as a string length. The difference in length you are seeing is probably just the 0.54 and 0.34 remainder of the partitions that has shifted the partitions on the table. If your tables are just a multiple of a string length, the easiest is to use "Number of rectanlge-strings" on the tables to simply divide the string in the correct number of partitions.
  26. Recently, we encountered a mountain-based PV project using bifacial modules with layouts involving multiple tilt angles and various azimuth orientations. When attempting to simulate this system in PVSYST, persistent errors occur. Could you clarify whether PVSYST currently supports simulating bifacial PV systems on complex terrain, particularly regarding the modeling of rear-side gain? If not, are there alternative solutions available? Thank you.
  27. Hi, our team often get blank reports after we update to a new version. this does not go away on a restart and it happens to at least 4 users on our team. see below
  28. Thanks! I used method 3, but there is an issue I explained in the picture below: although I have defined same rectangle sizes for rectangle string the final rectangles are not the same and I think it shouldn't be like that because 28 modules in series is valid for the whole scene.
