Mickael BLEIN joined the community
Lazare Fesnien started following PAN and OND files
Abeer started following PAN and OND files
REDSTAR SOLAR joined the community
Sandro started following Hybrid systems
Sandro joined the community
humandc joined the community
Léa Léauté joined the community
Sammy joined the community
Michele Oliosi started following Differing POA Irradiance Depending on Weather Granularity
Hi, Indeed the maximum number of rectangles is limited to 100. However, in most cases—even for large-scale projects—each table typically contains only a few strings, so this limitation normally is not issue. For example, if each table includes four twin half-cell panels arranged in portrait orientation, and each row of panels in the table corresponds to a single string, then the table would require eight rectangles in width (x-direction). Could you please clarify how the system layout is defined in your example? You can find more details about the partition model in the following help page https://www.pvsyst.com/help/project-design/shadings/electrical-shadings-module-strings/index.html?h=partition -
Hoffmann joined the community
gibijyly joined the community
Tohid joined the community
JStief started following Differing POA Irradiance Depending on Weather Granularity
Hello - I recently ran a test on the same variant using 60-minute, 15-minute, and 1-minute TGY (typical GHI year) data from a satellite weather provider. The 15-minute Egrid was less than 60-minute (due to sub-hourly clipping), but (surprisingly) the 1-minute result was the highest out of the three. This was due to higher Global Incident in coll. plane (POA, plane of array). The top line GHI varied by one - due to rounding differences per the satellite provider explanation. I'm hoping to better understand why the pvsyst simulation would have had this result. I reviewed the PhiAng and the hourly tracking angles are identical. See image below of the three different weather file runs' waterfalls. Thank you 1min, 15min, 60min pdf.pdf
Sanda Vulindlu joined the community
