Mangesh Punekar joined the community
Andi joined the community
AMUDHA joined the community
Zelon8 joined the community
SM24 joined the community
JRMiguel joined the community
Luzed6 joined the community
Miguel G joined the community
Edson08 joined the community
With the option "Load values from a CSV hourly file" you have full liberty to define the load profile exactly how you wish.
