Hello, At the moment, small shades smaller than cell size at the center of pv modules are not treated and do not create electrical shadings. This is something we hope to improve in a future version. Kind regards.
Michele Oliosi started following PVSyst vs pvlib tracking angle comparison
kapetav joined the community
Salih joined the community
Jun Lei joined the community
Arisa joined the community
- 8 replies
- irradiance
- rpoa
(and 5 more)
Botros joined the community
thanks! -
