Toni Kent joined the community
woohyeon joined the community
ESM Bülent YAKUT joined the community
Vjc Trading joined the community
Brokerzinfo joined the community
Broker Review Hub joined the community
Trading Guides joined the community
Top trending Broker joined the community
TimM joined the community
ginoticod joined the community
@sauld no you are right, there could be some losses that would be missed by this approximation. Unfortunately this is a compromise, because currently MPPTs can only receive identical strings in the System definition in PVsyst. However for most cases these losses are rather small. The most important is the string to string mismatch (usually shading effects are even smaller because you need a very specific shading pattern for the multi-MPPT to help). You could add an estimate of these losses to the mismatch losses manually. You can estimate them using a tool found from Home window > Tools. There is a similar discussion here (see the last answer by my colleague Luca): -
Hello Toni, The zone editing tool only supports fixed tables and trackers. If you need trackers, please tick the “Create tracking fields” option. For dome structures, there is no direct way to use the Fill Zone tool. However, you can refer to the following forum post, which suggests a possible workaround - Earlier
