harsh joined the community
The multi-MPPT feature and how to configure different sub-arrays to precisely define your system is explained in the following youtube tutorial:
No, due to by-pass diodes, the hot spot situation is not supposed to arise in normal operation.
Hi, I'm currently designing a 35 MWp grid-connected solar farm with a 100 MWh Battery Energy Storage System (BESS). The system is configured so that the BESS charges exclusively from the PV array — not from the grid. However, after exporting the hourly data from PVsyst, I noticed that values appear for EFrGrid (energy from the grid). When reviewing the simulation settings, I couldn’t find an option to disable grid import explicitly. Has anyone encountered this issue before? Is there a specific setting or workaround to ensure the simulation fully restricts energy import from the grid? Any guidance would be appreciated. Thank you!
Greg joined the community
Will the temperature increase and power decrease when local solar cells of photovoltaic modules experience hot spots be considered in the power generation simulation?thanks
I have 2 orientation. 1 with 28 panels x 440 Wp, and 2 with 16 panels x 440 Wp. I have inverter Deye SUN-15K-SG01HP3-EU-AM2 with 2 MPPT/ 2+1 string Input. What is optimal configuration.
AngyBG joined the community
When testing a few items for an internal standard about bifaciality I noticed the following item. Example project has a 3 portrait table with a 1m gap at the bottom and a 20 cm gap at the top. Basically when you have an east west system and you follow the pitch from the design it showcases the following: https://i.gyazo.com/4194337c998195b65b7d92bf96de2adb.png It looks like it keeps the entire space free instead of showcasing the other modules which will block the light from reaching the ground. This becomes apparent when you see the kWh/m² that gets produced extra. https://i.gyazo.com/70699f6dd7df697417825ba81073e433.pnghttps://i.gyazo.com/35ea7a63767ddf32e9e28ebc773525ca.png I solved it for now by giving it an interrow spacing of 1m to more accurately showcase the ground yield, even in this case it seems to be higher than that of a normal ground project.
Hi, For hourly estimation of both the production and the specific losses, you can export an Output File with any relevant parameters through the Advanced simulation window. From the hourly/daily values generated, you can do any analysis in an external tool such as excel.
- 5 replies
- shadings
- shading scene
Fatima6 joined the community
@Pete if you can send the zipped project (Export button in the project window) as well as your result tables (including the batch results file if you used the batch) to the email address support@pvsyst.com As usual with these investigations, comparing intermediate variables and not just the final energy gives good results in pinpointing the main effect. If ShdDLss is not the issue, then we should look at other variables before and after this point, to see if the energy increase is due to a specific loss or gain along the loss tree.
Hi again and thank you for your answer. I am still trying to figure out if there is a way to analyze the impact through the year of the shadow casting of the wind turbines. Like in my mind this are the steps I would follow: get the exported data on hourly basis for a year from the loss diagram, taking into account the %loss of near shading loss and electrical shading loss -> is it right? or should I take into account other losses for the shadings of the wind turbines? try to find a way to correlate the losses from the loss diagram through the year. Is there a study/methodology? For example, during Winter solstice I would have a bigger impact of shadows, so what fraction of the yearly near shading and electrical shading should I apply? and so through the year, on a monthly basis, how can I find the fraction of those year losses to be applied each month?
- 5 replies
- shadings
- shading scene
Cannot get custom tracker to save in v8.0.12. Once shade scene is exited, it remains all trackers.
If by inputs you mean inputs which are supported by PVsystCLI, then it will be technically possible. And if it is an internal tool only, then it would respect the legal frame. Please have a look at the PVsystCLI documentation to check what can be done with the tool.
Our team is developing a tool for solar plant feasibility study which requires an automated interface with PVsyst by which means like, if i feed the required inputs through my API, PVsyst should automatically consider those inputs and run to provide the result.
vallary joined the community
KKYOON joined the community
Hello, Can you tell me what version of PVsyst you are using ? As a workaround for site creation you can still use OpenStreetMap, option is available in Options> Preferences > Running. Regards, Laurent
Samar joined the community
Rebero Fabius joined the community
I fully expected energy to plateau as you mention dtarin. Perhaps my variant comparison above was confusing- so I have added some annotations below to help better explain my concern. At 50M, there should be very minimal row-row shading with of course the exception in the early / late parts of the day. To your point, we should not see an appreciable yearly energy increase. This "plateau does not occur until roughly 50m. @Michele Oliosi I did add the suggested shading loss to the 8760 data and plotted in excel. I do not see a significant change here. I can share my model - can you suggest a method for file sharing?
We are witnessing error in tracker angular movement. For example, at a specific time, tracker is supposed to be at an angle θ, tracker is actually at an angle of θ+/- 5Deg. Is it possible to do PVSyst simulation with tracker rotating angle error of +/-5deg to check generation loss due to tracker tracking angle error
When you have a nominal power, defined up to a given temperature, say 50°C, and an enhancced maximum power up to lower specified temperature, say 20°C, the simulation will use the curve shown in the inverter's definition dialog, page "Output parameters": The inverter temperature to be used during the simulation is defined in the "Energy management" dialog: Now the efficiency curve is specified by points at different powers, and interpolated between these points at each time step. If the actual power is over these points, the efficiency curve is simply extended linearly. -
After posting this, I realized the documentation may be referring to the saturation current evaluated at the actual cell temp, rather than the reference value. Is that the case?
smeredith started following Minimum saturation current
In PVsyst's documentation, it's stated that due to computational problems, PVsyst requires that the saturation current of a module at STC (I0_ref) be at least 0.01 pA, or 1e-14 A. However, after playing around with the single-diode parameters of modules in PVsyst, it seems like in reality the minimum saturation current of a module is 0.01 nA, or 1e-11 A. This is 1000 times greater than what is stated in the documentation. Is the value quoted in the documentation an error? Or is there something else going on here? Attached is a screenshot of the documentation text for reference.
