Good morning
I am trying to perform some simulations with backtracking. Everything is fine while the azimuth of the tracker system is aligned with N/S axis. But the real system i want to simulate has a N/S deviation of 21° to West and the system does not give me the option to simulate such scenario. In means of PLC logic i have implemented the backtracking also under conditions of deviations on the North-South axis, just needed a bit more of trigonometry formulas but it works (based on observations early morning and late evening for the last 6 months in a location in Northern Spain). Is there any way i can simulate the system with PV Syst?
Thanks in advance, Stavros
The backtracking with axis not facing south is allowed and works if you turn the whole trackers set toward not-south azimuth (i.e. when the alignment basis of each tracker is perpendicular to the axis, misalign parameter=0).
For axis with azimuths not perpendicular to the trackers aligment (i.e. not-null "misalign" parameter), the problem is much more complex, and I was not able to find an analytical algorithm for tilted axis.
Now for horizontal axis in this situation, the algorithm should be the same as in the Misalign=0 case, but I have indeed not developed this special case.
Thank you André
it seems that works if you apply the deviation in the object positioning. If i find any problem with the results, versus the recorded data i will come back to you. Have a nice weekend,
  • 3 years later...
Hey Andre,
Is the E-W mis-align with bactracking plan to be introduced in PVsyst in upcoming versions? Is there a timeline on it?
Thanks!
Taran
