Hardik1988 Posted April 12, 2014 Posted April 12, 2014 Im sorry i still don't understand how to utilize this option i'll explain my requirementI have a 10 degree tilt roof, 100m^2 on each of east and west side,(Approx 31.2kWp in total) I wish to know the performance, output of the entire system so i selected the heterogeneous option and set the azimuths at 90 and -90 and kept both orientations at 50% and 1)take two inverters in total (1 for each subfield) and about 8% undersized.2) take a single inverter with a multi mppt input (after checking the "mixed orientations " )In the second option i end up with three fields the last one being a mixed field,this field adds up the total power i.e 31.2 x3 !! I want an output file that shows the values if i were to use a single inverter configuration for both sides of the roof.What am i doing wrong ?
André Mermoud Posted April 16, 2014 Posted April 16, 2014 You are working with the version 5.You can uncheck the checkboxes representing the 2 undesired files. This is more simple in the version 6: you define only one sub-array with "Mixed" orientation.
Hardik1988 Posted April 17, 2014 Author Posted April 17, 2014 Thanks i just installed the beta version ,will do so .
