NavidSa Posted 3 hours ago Posted 3 hours ago Hello, I have a problem in a grid connected project by 25kW MID 25KTL3-X inverter. It's my pleasure if anybody can kindly help. I selected Trina solar 720Wp Panel for my project then I tried to connect one 18 modules string to one MPPT input and 2x16 modules str ings to the other MPPT input. Although I changed the limits of PnomRatio and Oversizing array/inverter nominal power to 1.6 or even 2 the "inverter power strongly undersized" error message is still not cleared and I can not go to simulation step.
Linda Thoren Posted 22 minutes ago Posted 22 minutes ago Hello, This limit that the error message is referring to is in the Project setting, not the advanced parameters. Kind regards
