PVsystUser Posted Friday at 05:26 PM Posted Friday at 05:26 PM I changed this number to different values ( 0.5, 2m, 30m) and it seems it is not reflected anywhere. at least when having multiple zones with different distance from ground , they all look to at the same heigh :
Linda Thoren Posted 21 hours ago Posted 21 hours ago Hello, I did a similar test in version 8.0.18 and is seems to work as it should on my side. The zone to the left is places 0.5m above the ground the the zone to the right 5m above the ground. If the issue persist, please describe further how to reproduce it. Kind regards,
Linda Thoren Posted 42 minutes ago Posted 42 minutes ago Please update to the newest version If you must stay at version 7, you can mark all the tables and move the selection using the arrow, or define the height in the tools section:
