Bakhtiyar Posted 5 hours ago Posted 5 hours ago Why sometimes my SLD doesn't light up even though there are no errors in the system?
Linda Thoren Posted 4 hours ago Posted 4 hours ago For certain scenarios it is not yet implemented, such as for multi orientation daily sharing. In the case in your print screen it is probably because you do not have a multiple between the number of strings and MPPTs in the second sub-array. You should have an orange warning in that sub-array indicating this. You should here create an additional sub-array for the strings of 19 modules, one sub-array with 2 strings and 1 MPPT and a second with 1 string and 1 MPPT. This is further explained in the following youtube video:
Bakhtiyar Posted 3 hours ago Author Posted 3 hours ago Now how can I enter the length and cross-section of the cable for each string? I can't enter values here, the cell is not lit.
