I defined a custom load profile as per the PVsyst template and imported it into PVsyst. However, after importing, I noticed some unexpected sudden spikes in the preview graph (screenshot attached, seem happen at 00 hour).
  • The spikes do not exist in my original input file.
  • They only appear after the file is loaded into PVsyst
  • The rest of the profile seems to follow the expected trend.
Could you kindly advise what might be causing this?
  • Is it related to file formatting, delimiter issues, or data resolution mismatches?
  • Are there any best practices to avoid such spikes during import?
Any guidance would be greatly appreciated.
image.png.f31804f0884b673a365dac932ef2b80c.pngimage.png.018477e15666ed4cc455ceaf0f74da55.png
Does the peaks only appears in the preview graphics or is there in issue with the actual values in the input? Does the Annual need and the CSV source file to the left of the graphic correspond to the original file?
You can possibly try to run a simulation and export the results to verify that the simulation is made with the correct values
