cson Posted June 12, 2025 Posted June 12, 2025 As I understand, the POA value should be greater than the GHI value, but why does it show in our project the result like this?
Linda Thoren Posted June 12, 2025 Posted June 12, 2025 The global irradiance in the plane of the array (GlobInc)depends on the tilt and azimuth of your system. In general, one would choose an orientation of the panels in a way that maximizes this irradiance, which is why the GlobInc is usually higher than the irradiance on a horizontal plane. When defining a fix tilted plane, you find a "quick optimization tool", illustrating in an order of magnitude what you could expect to gain (or lose) compared to a horizontal configuration at your site.
