Victor3361 Posted June 3, 2025 Posted June 3, 2025 (edited) Good afternoon, I have created a new SIT file and I want to make a customized MET file with another source file. While making the MEF file I have selected -1 Time shift, with universal time. Neverthless I am receiving a message that I should specify an Hour shift of -1 in the format file and reimport. How can I manage to change the shifted time so it is complying with the Clear Day model? Kind regards Edited June 3, 2025 by Victor3361
Linda Thoren Posted June 4, 2025 Posted June 4, 2025 Hello, Indeed the workflow would be to precisely define the coordinates for where the site, define the MEF file and run the conversion of the data. If PVsyst suggest a time shift, go back to the MEF file and define the indicated time shift and run the conversion again. If the issue persists, please send your data to support@pvsyst.com and we can have a closer look.
