JamesLenton Posted April 24, 2025 Posted April 24, 2025 Hello, Please can you help explain why irregularities like the one shown in the image attached occur in PVsyst? In this instance power drops from 15 MW to 0 MW in 30 minutes, mid-day in the summer. To me this seems impossible, even with partial cloud cover. Could be a result of poor weather data, however I experience similar things with Meteonorm and PVGIS.
Linda Thoren Posted April 24, 2025 Posted April 24, 2025 Hello, To better understand the results, you can consider adding additional parameters—such as irradiance—to assess whether a drop in production is due to variations in weather data or other factors. In the Advanced Simulations, you also have the option to export hourly data as a .csv file, allowing for deeper analysis of any relevant simulation parameters.
JamesLenton Posted April 25, 2025 Author Posted April 25, 2025 Hello, The cause of the drop appears to be the irradiation. Do you know why this could occur, it seems unrealistic.
Linda Thoren Posted May 7, 2025 Posted May 7, 2025 Indeed it seems a bit surprising that the global irradiance would be 0 for a few hours in the middle of the day, but indeed possible. Using another weather data provider, do you see similar drops in irradiance? If you import a weather file with missing data, these hours will be considered as 0 in PVsyst.
JamesLenton Posted May 12, 2025 Author Posted May 12, 2025 Hi Linda, We tried PVGIS and Meteonorm and saw similar anomalies on different days also. Weather data imported from those 2 sources shouldn't have missing data however? James.
Auriane Canesse Posted May 12, 2025 Posted May 12, 2025 Hello James, If the dip in irradiance is not due to missing data, I would need your files to look into this issue in more detail. Could you send your project at support@pvsyst.com ? Auriane
JamesLenton Posted May 13, 2025 Author Posted May 13, 2025 Hi Auriane, I have since made change to that variant, and when re-running it I am not seeing anything as extreme as the situation I posted above. However, there are still some very fast drops from almost max power to very low power (but not zero). I have sent across the project files to PVsyst support email anyway for you to investigate. Kind regards, James.
