Posted (edited)
Hi all,
I been learning to use Pvsyst, i recently try to compare my simulation with my friend.
In the loss diagram i found that the Irradiation level for both are different. Any other setting or configuration i might need to look at given the location set point is the same.
image.png.e87fa0e1c95ee40854fdfd8cf3bd59e1.pngimage.png.aca505631fa0b9656d810dfde581b73f.png
Edited by Gary Tan
Indeed, the first input of the Global horizontal irradiation is different between the two diagrams. Verify that you have the same coordinates and are using the same weather data provider.
