It says Orientation #1 Dome front face, Tilt 5 degree, Azim 135 degree: The area of the 3D fields is lower than the area of the modules defined in the system subarrays. How can i expand this 3D fields?
Dear Vasil,
Depending on your project, you can add more PV modules in the 3D scene, but they must correspond to your "Orientation #1." PVsyst will then automatically match the final surface area of this orientation between the system definition and the 3D scene definition.
Regards,
  • 10 months later...
I am designing a hybrid (roof + carport) PV system and getting several error messages referenced in the attachments. Could you help me to correct the errors?
The error message indicated that the 3D scene and the system definition does not match. For instance, in the first orientation (tilt 5° and Azimuth 180°), 1564 modules are defined in the system but only 1427 in the 3D scene.
Verify also that the orientations, are correctly defined. In PVsyst, Azimuth of 0° is towards the equator, and 180° thus the opposite orientation (North is the northern hemisphere and South is the southern hemisphere)
4 hours ago, Linda Thoren said:
In the 3D scene you can define each table by modules. In the Orientations management you find detailed information about what is defined for each orientation
In the following youtube tutorial you find examples of how to define a 3D scene and how to navigate in the window:
On our website you can do a request for a training sessions on various topics:
https://www.pvsyst.com/en/training/consulting/
image.thumb.png.0eb0560be1dfb00d6cd364db45f5487c.pngimage.thumb.png.2112024a6ab012970fc58f7134c847db.png
