NGD Posted December 12, 2024 Posted December 12, 2024 Hello, When I import a scene from PVcase, in several occasions the tables take two different orientations automatically, either modules in portrait (3 rows x 24 modules) or modules in landscape (24 rows x 3 modules). This was not a major issue in PVcase 7 as in the orientation manager you could override this. However, in the new PVsyst 8, with and EW system I can not simulate the bifacial option as the widths of the tables are not the same (an error pops up). If I change manually in the list of objects the configuration of these "wrong" tables, they move all over the scene. How can I fix the error in importing/reading correctly the tables? This would also reduce the threshold of the setting in max. spread of azimut for the same orientation. Note: this is not an issue of this particular project as it has happened before in multiple projects. Many thanks!
Michele Oliosi Posted December 17, 2024 Posted December 17, 2024 Hi, when importing, you should be wary of the following option: This will define the orientation properly. You can also try the East/West option. Note that you should not simulate East/West dome systems with a bifacial model. This cannot yet be calculated in PVsyst, a dedicated model needs to be developed still. In principle, the bifacial gain of E/W domes is negligible, unless the height of the dome is important.
