rMotta Posted November 7, 2024 Posted November 7, 2024 What this new feature means? How to allow the hourly simulation to use the correction properly?
Michele Oliosi Posted November 8, 2024 Posted November 8, 2024 If you import sub-hourly data you can then use that as an enhanced MET file in your simulations. Here is a help page that breaks it down: https://www.pvsyst.com/help/physical-models-used/grid-inverter/subhourly-clipping-correction.html
dtarin Posted November 9, 2024 Posted November 9, 2024 Are there any plans to include the clipping correction button under the known format method? Certain weather data sources provide sub-hourly data in time-series format in a single file, which is useful to import through the known format menu, since it will generate each year automatically into a separate weather files. Otherwise, we will be required to separate the file into 22 files then import through the custom format each file. The other option would be to allow the custom import feature to import more than one year, automatically generating a new file for each year (and not have the menu pop up each time asking the user to check the file, which should come only at the end of the file).
Michele Oliosi Posted November 11, 2024 Posted November 11, 2024 @dtarin yes there are actually plans to completely rewrite the weather data import, to address these two issues and others in one go.
footloosiety Posted November 27, 2024 Posted November 27, 2024 Hi Michele - adding onto this, is it currently possible to export a subhourly production timeseries if you have imported subhourly data using the methods described above, or is it only for suhourly clipping calcs now?
Robin Vincent Posted November 29, 2024 Posted November 29, 2024 No, the simulation itself is still hourly-based. We only extract additional info from sub-hourly weather data to correct the clipping losses.
Li-ESS Posted February 17, 2025 Posted February 17, 2025 Hope it can be realized soon. The simulation can be sub-hourly based and user-defined: 10 min, 15 min or 30 min... On 11/27/2024 at 2:05 PM, footloosiety said: Hi Michele - adding onto this, is it currently possible to export a subhourly production timeseries if you have imported subhourly data using the methods described above, or is it only for suhourly clipping calcs now? On 11/29/2024 at 9:05 AM, Robin Vincent said: No, the simulation itself is still hourly-based. We only extract additional info from sub-hourly weather data to correct the clipping losses.
