Abeer Posted September 23, 2024 Posted September 23, 2024 How can I perform a simulation for bifacial modules with multiple orientations and shading calculations from a shading scene without changing the field type to "unlimited sheds" in the orientation tab?
André Mermoud Posted September 28, 2024 Posted September 28, 2024 Sorry, with the bi-facial model presently implemented in PVsyst, you cannot define a bifacial system with several orientations. This will be possible in the next version 8.0.0.
emily.denz Posted November 22, 2024 Posted November 22, 2024 I would like to simulate a 90° PV ground-mounted system for my PV park in PVsyst. How can I set it up in PVsyst if I have a module table with two modules stacked on top of each other, where the bottom module is oriented towards the east with its 100% side, and the top module is oriented towards the west with its 100% side?
Linda Thoren Posted November 22, 2024 Posted November 22, 2024 Indeed this is now possible in version 8! You should define two orientations, one in west and one east, either with unlimited sheds (that doesn't require a 3D scene definition) or fix tilted planed where you should also define the layout in the 3D scene. Define each sub-system in a sub-array and define the bifacial parameters for each sub-array (height above ground etc)
emily.denz Posted November 28, 2024 Posted November 28, 2024 Thank you! Additionally, do you have any recommendations for modules with high bifaciality that could be used for this setup?
