bturner Posted January 8, 2014 Posted January 8, 2014 I'm trying to produce a 12 x 24 table after the simulation (Hours vertically and months horizontal with MWh as an output. Can someone give me some assistance? Below is a similar tableAverage Wind Farm Production (MW) Month Hour January February March April May June July August September October November December Grand Total0 25.61 25.66 28.24 29.63 28.27 29.71 28.56 27.82 28.28 30.25 28.72 26.21 28.101 25.69 26.82 28.37 29.35 28.39 29.25 28.05 26.57 27.48 29.70 28.10 25.97 27.822 26.27 27.07 28.93 29.72 29.27 29.45 26.90 26.24 27.17 29.77 28.52 25.68 27.913 27.67 25.92 28.46 30.04 29.34 29.45 26.43 26.25 26.20 28.50 28.45 25.44 27.694 28.42 25.50 28.40 30.23 27.83 28.54 25.89 25.85 26.34 27.64 28.28 25.43 27.375 27.86 24.58 28.58 30.20 28.36 27.88 24.33 24.30 24.49 27.41 27.82 25.41 26.786 26.82 24.05 28.75 29.05 26.79 26.15 20.79 22.49 23.43 26.47 28.07 24.84 25.647 25.49 22.71 27.26 26.86 24.68 22.93 17.25 16.31 20.90 25.19 28.12 24.39 23.488 23.33 21.38 24.88 25.99 24.27 23.11 16.08 14.19 17.65 20.56 24.72 22.46 21.529 19.72 19.70 23.82 25.31 22.86 23.18 14.51 13.83 17.95 20.33 22.08 20.15 20.2610 18.02 18.56 22.59 25.02 21.95 22.99 13.64 13.06 17.98 21.18 22.08 18.78 19.6211 18.06 18.01 22.32 24.50 21.54 23.27 14.32 13.12 17.78 21.82 22.28 18.91 19.6412 17.97 17.83 23.02 24.99 21.68 23.86 15.37 13.26 17.11 21.63 23.31 18.50 19.8613 18.04 18.44 23.43 25.18 22.06 24.67 16.54 13.25 16.49 21.25 24.09 18.50 20.1414 18.18 19.43 23.47 25.25 21.79 25.61 18.14 13.21 16.57 22.16 24.45 18.34 20.5215 18.58 19.27 23.40 25.06 22.02 26.27 20.05 15.12 17.30 22.15 24.17 17.66 20.9016 18.12 20.02 24.05 24.38 22.69 27.89 21.22 17.59 18.03 21.96 23.11 17.00 21.3317 18.98 20.42 23.64 25.24 22.81 29.02 22.42 20.01 18.18 21.17 22.90 17.64 21.8618 21.72 22.12 24.05 24.30 22.69 29.42 23.87 19.21 20.02 24.19 24.78 19.89 23.0119 23.43 24.18 25.35 24.70 24.56 29.22 24.30 22.49 23.06 26.61 26.21 22.39 24.7020 23.81 25.04 26.48 27.26 26.47 30.28 27.45 27.82 25.82 27.82 27.75 23.12 26.6021 23.92 25.82 28.30 28.63 27.50 31.88 27.89 29.32 26.31 28.19 28.53 24.62 27.5922 24.59 26.22 28.65 30.01 28.33 31.89 29.16 29.22 27.51 29.25 28.34 25.85 28.2723 25.42 26.10 28.69 29.78 29.12 31.40 28.94 29.20 28.21 30.48 28.87 26.54 28.59Total 22.73 22.65 25.93 27.11 25.21 27.39 22.17 20.82 22.06 25.24 25.99 22.24 24.13
Bruno Wittmer Posted January 9, 2014 Posted January 9, 2014 PVsyst does not foresee to produce directly tables with hourly values of the 'average' day for each month.If you want to create such a table, you need to create a table with hourly values for all the days of a year and export it to some calculation software (e.g. MS Excel) where you can perform the monthly averaging for each hour of the day.The procedure is the following:In the simulation dialog, before you start the simulation, you have a button named 'Output File'.Here you can select with much detail what kind of values you want to save, in which kind of format and specify an ouput filename.In your case you would want to select 'hourly values' and include 'Energy injected into grid' in the list of variables.The values will be saved as comma-separated values (CSV), which you can easily import into many analysis software packages.
Bruno Wittmer Posted January 13, 2014 Posted January 13, 2014 This kind of table is now implemented in the next PVsyst Version 6.18.
just _solar Posted July 29, 2020 Posted July 29, 2020 I am not able to find the way to generate 12x24 data, can you please walk me through steps ? Thanks!
dtarin Posted July 31, 2020 Posted July 31, 2020 I am not able to find the way to generate 12x24 data, can you please walk me through steps ? Thanks! Here is a sample file, this should help.
gonecrawfishin Posted January 29, 2021 Posted January 29, 2021 That file is no longer available, does anyone know how to export a 12x24 table?
