mohamed abdelkader Posted June 20 Share Posted June 20 I have finished a simulation , i found that the energy produced to injected to the grid is 4118645 kWh/year i am attaching the calculation report . i have extracted in excel sheet to know how much energy produced for each hour . when i summed the total values of kW for whole the year , i found that the energy injected to the grid is 5226724 which is different that the total value in the report ( uploaded a snap shot) . could you understand this difference ? . also why in some hours i find power produced in negative ? HY1_Project.VC0-Report.pdf Link to comment Share on other sites More sharing options...
Michele Oliosi Posted June 21 Share Posted June 21 Hi, It seems excel doesn't read your entries as numbers. Usually numbers are right-justified, i.e., I suspect most entries are read as text or some other type of cell. Please check the cell type, and make sure that all values are actual numbers. Regarding the negative values, it is due to night auxiliary consumption, either from your “Detailed losses” > “Auxiliary losses” definition, or from the inverter definition, or from the transformer night iron losses. Link to comment Share on other sites More sharing options...
mohamed abdelkader Posted June 21 Author Share Posted June 21 Hello , Thanks for your kind reply . some cells are are read as general i have adjusted all of them to numbers but also the summation is different than the produced energy in the report . is there any way to send you the excel sheet ? Link to comment Share on other sites More sharing options...
Michele Oliosi Posted June 21 Share Posted June 21 Sure, you can send the original CSV, the modified Excel sheet, as well as the report, over to support@pvsyst.com. We will look into it. Link to comment Share on other sites More sharing options...
