avelasco Posted May 4, 2024 Posted May 4, 2024 Does the PVsyst irradiance optimization feature stow trackers to a flat (phi=0) position during all times of high diffuse conditions? What is the diffuse ratio that triggers a flat position? Are there times when the tracking angle would be non-zero? For example, fully covered weather makes sense to go flat, but what if its only partially cloudy.
André Mermoud Posted May 7, 2024 Posted May 7, 2024 The tracking angle optimization doesn't work with diffuse thresholds. At each time step, the simulation evaluates the optimal tracking angle on the basis of the transposition model: the angle is adjusted in order to get the best transposition result GlobInc, considering the Beam and Diffuse components.
beredisqq Posted May 12, 2024 Posted May 12, 2024 Regarding times when the tracking angle would be non-zero, the optimization feature adjusts the orientation according to the best irradiance received by the trackers. So, in conditions that are only partially cloudy, where direct irradiance still plays a significant role, the trackers would not necessarily be in a flat position. Instead, they would adjust to optimize the combination of direct and diffuse irradiance received
LauraH Posted January 14, 2025 Posted January 14, 2025 What resolution are the tested tracker angles, every 5 degrees? 2 degrees? .....
