hvf Posted January 19 Share Posted January 19 (edited) Hello, everyone! I am working on a project with 30x 185kVA inverters (5.55MVA total). I am running two scenarios: Power Factor of 1, Grid Limit: 4,995kW Power Factor of 0.90, Not Grid Limit As you can see, both scenarios have an Active Power Capacity of 4,995kW and I was expecting to see the same energy produced. However, I am getting different values. Could someone explain where is my reasoning wrong or add some clarity to what is happening? Thank you for your time. Best, Hector P.S.: I am using PVsyst 7.4, Trial Version. Edited January 19 by hvf Link to comment Share on other sites More sharing options...
Linda Thoren Posted January 22 Share Posted January 22 Dear hvf, The grid limitation is reflects a scenario where the grid manager impose a limit to the injected power to the grid. If your system at certain moment produce higher then this limit, it will be managed by the inverter as a clipping loss. There is a help page here explaining this further: https://www.pvsyst.com/help/grid_power_limitation.htm The power factor is the ratio between active and apparent power, i.e. Cos(phi) and does not limit the power to the grid at a certain threshold. The active power is the power obtained along one sinus period, when we integrate the product of the instantaneous Voltage by the Instantaneous Current at each time step. This results in a multiplication by the cosine of the phase shift: Pactive = Ueff * Ieff * Cos(phi) expressed in [kW]. The reactive power is the vectorial difference of these contributions: Preactive = Ueff * Ieff * Sin(phi) expressed in [kVAr]. Following help page explain the Power factor further: https://www.pvsyst.com/help/power_factor.htm Indeed, if the Nominal AC Power is defined in Apparent power in the inverter file, the two variants should give similar results. To assist you further please provide us with the loss diagrams for the two variants, or send your project to support@pvsyst.com Kind regards Link to comment Share on other sites More sharing options...
