Vera Posted January 11, 2024 Posted January 11, 2024 I'm relatively new to PVsyst and am seeking guidance on simulating trackers positioned on a hill with varying slopes. Specifically, I'd like to know how to customize the North/South tilt for each individual tracker. Here's the desired configuration: Tracker 1: 0° Tracker 2: 1° Tracker 3: 2° Tracker 4: 3° Tracker 5: 4° Tracker 6: 5° I appreciate any assistance or advice you can provide. Thank you!
Michele Oliosi Posted January 12, 2024 Posted January 12, 2024 In this case, it is often best to go through the advanced object selection: https://www.pvsyst.com/help/near_shadings_advancedselection.htm If the tilt column is not present, you can right-click on any column header to see the selection of columns:
