Edwin Tellez Posted December 13, 2023 Posted December 13, 2023 I have a project with fixed structures of different configurations 3Vx28, 3Vx14, 2Vx14 with bifacial photovoltaic modules. There is a .pvc and .csv file for shadow analysis, but when activating the bifaciality function of the modules, PVSyst does not allow the simulation to be carried out: A pitch is considered between 2V tables of 6 m and between 3V tables of 9m. The types of tables considered for the project are a product of the typology of the terrain, seeking to optimize earthworks. Will it be possible to make some type of adjustment to the PVSyst parameters that allows the simulation to be carried out, activating the bifaciality function of the modules with these types of fixed tables (2V and 3V)? thank you so much for your support and attention.
Eduardo Posted December 13, 2023 Posted December 13, 2023 Dear Edwin Tellez, you will need to change the simulation. Separate the different configurations as project variants. PVSyst is unable to simulate because the panel arrangements are too physically different. The "unlimeted sheds" option requires homogeneous distribution of the photovoltaic plant as it is a limited resource so far.
Michele Oliosi Posted December 14, 2023 Posted December 14, 2023 I agree with Eduardo, here the problem is tables which are differently-sized. If their “width” (how tall they are) is different, PVsyst will not be able to run the simulation no matter what. This will be possible in v8, but not before (should be ready sometime next year).
