Vladislav Iliev Posted November 23, 2023 Posted November 23, 2023 Hello. I have the following staging: same site and two single axis tracker (N-S) variants: - idenatical parameters expet the azimuth.One is 0 degree , one is -47degree. - Backtracking is ON, Latitude 44° 49' 0" N, flat/No terrain Results of simulation indicate better overall performance of the 47degree. Whitch contradicts with articles about performace of deviations from the 0 azimuth. Main difference comes from near shadings. Can someone explain those results? Comparison attached. Sincerely, Vladislav
Michele Oliosi Posted February 26, 2024 Posted February 26, 2024 This indeed is inconsistent. We have observed recently that for trackers that do not have azimuth zero, there is a bug for a certain diffuse shadings calculation mode. I suspect this is what is happening here. In the 3D scene, if you go to Tools > Tracker diffuse shadings definition, you can switch between the modes: automatic (=central tracker above a threshold* number of trackers / = all trackers below that threshold*) central tracker (fast) custom tracker (fast) all trackers (most accurate, slower) The "Central tracker" and "Custom tracker" modes do not work well with azimuths away from zero because the neighbor identification fails. I would suggest to use the mode "all trackers". * The threshold can be modified in the advanced parameters: Read https://www.pvsyst.com/help/tracking_diffuse.htm for more details.
