Vera Posted November 3, 2023 Posted November 3, 2023 I am very new to PVsyst so I apologize if the question is due to my lack of understanding. A customer has asked me to Run PVsyst with the following modules: PV: Imperial Star 665W Inverter: 125kW 684-1450VSunny Highpower SHP 125-US-20-Peak3 I was then asked to run PVSyst with 17, 18, 19 & 20 string variations, but the range given by PVsyst is 21-29 strings. At 19 and 20 strings I can run the simulation with an orange warning but with 17 and 18 strings I am given a red warning that the array Vmpp is far lower than the inverter minimum operating voltage. Does this mean that I should report to the customer that it's not possible to have less than 19 strings, or is there some variable I am missing here that would allow the lower strings? Thank you, Vera
Muhammed Sarikaya Posted November 7, 2023 Posted November 7, 2023 Dear Vera, This is precisely what you need to understand: For this inverter to function, there is a minimum voltage requirement. The 'operating voltage' range is listed as 684-1450 V. It's important to note that temperature affects voltage; the higher the temperature, the lower the voltage. That's why we base our calculations on a module temperature of 60°C. I suggest increasing the number of modules or opting for an inverter with less power. If you need any assistance, please don't hesitate to contact me. Regards, Muhammed Sarikaya
