Michalis Angeli Posted October 19 Share Posted October 19 (edited) Hello, i would like to ask about shading scene. The distance (to this example 4 m) that named pitch N - S between 2 tables of panels is that I noted with green line, in below picture? Edited October 19 by Michalis Angeli Link to comment Share on other sites More sharing options...
Hizir Apaydin Posted October 19 Share Posted October 19 8 minutes ago, Michalis Angeli said: Hello, i would like to ask about shading scene. The distance (to this example 4 m) that named pitch N - S between 2 tables of panels is that I noted with green line, in below picture? Dear Michalis, Yes this is correct. The pitch corresponds to distance between counterpart points of two tables of the same field. Regards Link to comment Share on other sites More sharing options...
Michalis Angeli Posted October 19 Author Share Posted October 19 Very well, thank for your immidately response. Furthermore i would like somethnig else. Is there the opportunity to define angle or azimuth in an elementary shape like in parallilepided? I want to position it in a roof with specific angle and azimuth. Link to comment Share on other sites More sharing options...
Hizir Apaydin Posted October 19 Share Posted October 19 55 minutes ago, Michalis Angeli said: Very well, thank for your immidately response. Furthermore i would like somethnig else. Is there the opportunity to define angle or azimuth in an elementary shape like in parallilepided? I want to position it in a roof with specific angle and azimuth. Dear Michalis, After adding the object to the 3D scene, you can select it, then click on rotate icon and set its tilt and azimuth as shown below: Regards Link to comment Share on other sites More sharing options...
Michalis Angeli Posted October 19 Author Share Posted October 19 Okay thank you very much is more easy than I thought! Thank you. Link to comment Share on other sites More sharing options...
