Dominik Damberger Posted June 29, 2023 Posted June 29, 2023 Hello everyone, the following section of the PVsyst-help suggest a "limit shading" profile angle of below 18 ° to 20 °: https://www.pvsyst.com/help/shed_optimization.htm However, I noticed that in my simulations higher energy yields will be calculated when setting higher values for that angle. Is it possible that this section of help needs to be updated to consider the commonly used half-cell technology as well? I suspect that since the two halfs of the modules can function seperately (gound-mounted system, fixed tilt, vertical orientation), the larger shading has less of a negative effect than the positive effect of the better tilt for the sun (middle-european project locations). And since formerly by shading a part of the module the whole module was affected it was much more important to avoid shading, therefore the values of below 18 ° to 20 °. Thanks!
Michele Oliosi Posted June 29, 2023 Posted June 29, 2023 Thanks for the remark. Yeah if you consider modules that are less sensitive to shadings (such as half-cut modules) the optimum may change. This page has been written some time ago so I am not surprised it may need an update or two.
khloerep6 Posted July 25, 2023 Posted July 25, 2023 As you mentioned, half-cell technology allows solar modules to function independently, which means that shading on one half of the module might have a different impact compared to traditional full-cell modules, where shading affected the entire module. In the case of half-cell modules, the larger shading might have less of a negative effect on energy yields than the positive effect of better tilt for the sun, especially in middle-European project locations.
