Debbie Posted May 22, 2023 Share Posted May 22, 2023 Hi PVsyst team, In version 7.3.4 I am finding that computing the integrals for diffuse is taking about 6 minutes each time I run the model again (even if I don't change the near shading scene). Usually this doesn't happen when I set the reference diffuse tracker to a custom selected tracker. Is this a change in the new version? Thank you, Debbie Link to comment Share on other sites More sharing options...
Michele Oliosi Posted May 23, 2023 Share Posted May 23, 2023 If you have selected the option "all trackers" or if the threshold number found in the advanced parameters (default 40, but you may have changed) exceeds the total number of trackers in your 3D scene, the diffuse shading factors will take some time since all trackers will be used for the calculation. The time it takes depends drastically on the complexity of the scene and shading objects. Link to comment Share on other sites More sharing options...
Debbie Posted May 26, 2023 Author Share Posted May 26, 2023 If I select the "custom tracker" option, shouldn't that prevent it from using all the trackers in the calculation, regardless of the advanced parameters? (currently at 40 for mine). I will see if it happens again, now that I'm running a new model, and will report back. Link to comment Share on other sites More sharing options...
Michele Oliosi Posted May 30, 2023 Share Posted May 30, 2023 Sure, if you select custom tracker only that tracker (green) and the shading ones (orange) will be considered. Sorry in my previous answer I meant "if the threshold number found in the advanced parameters (default 40, but you may have changed) exceeds the total number of trackers in your 3D scene" + having selected "automatic". If you select custom tracker this will override the "automatic" setting. Link to comment Share on other sites More sharing options...
