C. Amorevole Posted May 3 Share Posted May 3 Hello PVSyst forum!! I need your help. In the ohmic losses definitions I had an issue to input some characteristics of my implants on PVSyst. I am talking about an utility scale project: my PV system is characterized by an in-out system cabling for the subarrays: the wires go out from a power station (structure in which there are many electro-mechanic instruments such as inverters, combiner box, transformers, ecc) of a subarray and go in a new power station of a different subarray, obviously the new cables that go out from the new power station wil have a larger section. This helps to use less cables length, saving money. I wonder if this configuration may be implemented in PVSyst. Can anyone help me solving this issue? Link to comment Share on other sites More sharing options...
André Mermoud Posted May 4 Share Posted May 4 I don't understand well your problem. If each subarray is connected to a power station including the inverter, the ohmic losses should be accounted as "AC losses after the inverter" (in the dialog "Detailed Losses > Ohmic losses"). In this case you should evaluate an equivalent resistance of the wires between the output of each substation and the injection point. Link to comment Share on other sites More sharing options...
