Salvo Posted April 26, 2023 Posted April 26, 2023 Hi everyone, I tried to import a plant layout (DWG) into Pvsyst, converting it into DAE. The problem is that it is very heavy to manage, so I thought about using the PVC format to see if it is easier to manage by the program. Is it possible to convert a DWG/DXF file to PVC? Thanks in advance Regards
Stéphane Posted April 28, 2023 Posted April 28, 2023 Dear Salvo, Thank you for reaching out. There is no way to convert DWG/DXF files to PVC files. However the conversion from DWG to DAE shouldn't be very complex. Here is a thread explaining how to do it : https://forum.pvsyst.com/topic/3210-how-to-convert-an-autocad-dwg-to-dae-from-sketchup-in-order-to-import-it-to-pvsyst/#comment-8774 I hope this helps. Regards, Stéphane
Salvo Posted April 28, 2023 Author Posted April 28, 2023 Dear Stephane, I tried to do this operation, but the problem is that DAE file it is very heavy to manage. Thank you for your answer. Regards Salvatore
Stéphane Posted May 3, 2023 Posted May 3, 2023 Dear Salvo, I am sorry that you are encountering issues when trying to load a DAE file in PVsyst. You can send us the file to support@pvsyst.com and describe in details the issue you are facing. We will try to help. Regards, Stéphane
Dkraemer Posted June 13, 2024 Posted June 13, 2024 Hi Salvo, We have gotten around this issue by using a Third Party AutoCAD add-on called PVCase. Fantastic solar design tool. I'm currently developing sites upwards of 1GWac/1.3GWDC. Along with developing the full Solar design (Layout, cables, blocking, civil assessment, shading, etc.) it can generate .pvc files for your layout including shade objects. I'd urge you to look into it. www.pvcase.com and see Ground mount option. They also have Roof Mount that exports to PVsyst also. Good luck!
